1 - 3 of 3 Posts
Hello all...Have not been on in a few days.....Got a question, took the 10 out today to work, and when coming home, I took a curve pretty steep, the FI light went on, then after about 10secs went out again. Brought the bike home, looked in the tank, looks pretty full, not all the way, about 1/4 tank, moved the bike to one side and it did it again, then went out again. Is this just natual or is there a problem???? Thanks...
Bragg...
Discussion Starter #2
And I Filled it up before I went to the track, drove it to the track (15 Miles one way) Made about 12 Passes at the Track, drove it home, took it to work 5 Miles one way....So I'm thinking it is just low. I just have a Muzzy Slip on.....
Maybe a loose connection. :dontknow: Have you done any work to it recently? Low fuel shouldn't cause an FI light. Might want to check to see if it threw a code.
1 - 3 of 3 Posts
