1 - 3 of 3 Posts
Hey guys, Just wanted to know if the PC secondary fuel module is needed when installing a PCV on the 09m zx10 with just a yoshi r55 slipon,k&n (street) air filter and possibly a link pipe?
Speaking of which, are their any link pipes available that would connect the stock headers to the yoshi r55 slipon as a direct bolt on, and where could i purchase this pipe?
Eventually i plan to go a full akrapovic system but for now will just make do with what ive got till funds are available..
Cheers
Its is not really needed with what you have... The SCM is good if you have alot of mods that will require more fuel than you bottom for injectors can handle. With what you have the duty cycle on your bottom four injectors is not high enough for you to warrant paying 250 for a scm...
1 - 3 of 3 Posts
