1 - 4 of 4 Posts
mmmmm......I got my MC today and I can't see how the reservoir is going to fit.
I even tried using the 05 reservoir but it seems the deal is at the elbow coming out the MC...on the 05 it goes parallel to the clip-on....on the ZX14 it points almost forward...putting the reservoir too far out to be mounted on the stock anchor. Anybody with pics on this?
Thank you.
racer155
Discussion Starter #2
ok, I'm an ass...I got the elbow thingy figured out (didn't know it rotated:headshake)so I think the only issue is the lenght of the hose between the reservoir and the master cylinder.
Can anyone using this mc confirm this?
Thanks,
racer155
Can anyone using this set-up, post a pic or confirm the hose between the reservoir and MC has to be replaced by a longer one?
thanks.
racer155
The hose doesn't have to be replaced, but it's a good idea. If you use the original reservoir mount and bend the hose straight instead of 90* it works fine. A little tight, but fine. Let me know if you want pics.
1 - 4 of 4 Posts
