1 - 3 of 3 Posts
I have found alot of sites that sell aftermarket Velocity Stacks for my 08. They range from $250 to $350. Then I called the closest dealership and priced the stock ones for cylinders 1 and 4. He told me they have to be differant in some way because there are 2 differant part numbers. From the pic he said that it looked like the screw holes were in differant places. But that they were $8.70 each. Does any one know if they will work on cylinders 2 and 3? All the throttle bodies are the same size. I am just wondering about the screw holes. It would save me ALOT of money.
That setup would simply make you loose power.
For some reason stacks for cylinders 2 & 3 have to be taller. Dyno tests have prove this.
There´s no way to save money on this mod. Best way is to leave the stock setup.
You may want to call Mark Salvisberg at Factory Pro. He has done extensive research.
:iamwithst Hit up Factory Pro, they should provide you some good info :thumbsup:
1 - 3 of 3 Posts
