CNC machined from a solid block of impact-resistant acrylic plastic, Proton Turn signals offer the perfect fit and finish to compliment your ZX10R. These turn signals are bright too. Not only that, but it is possible to adjust the blinking effect from normal, to strobe to fade and you don’t need to purchase a separate flash controller to do this! Simply remove your old signals, install the Proton units and wire them with the included hardware to set how you want them to blink. Aside from moving bodywork, installation is quick and painless.
Available for 04-06 ZX10R models.
These are not yet on our website. To get yours, call TJ at 866.931.6644 ext 817 or send a note to FORUM at RIDERSDISCOUNT dot COM with PROTON in the subject line along with the year and model of the bike you ride to get a set of these sent your way fast.
Butt connectors included.
Machined from solid, the acrylic material used is UV-treated so these turn signals won’t yellow over time.
Onboard circuitry negates any need for a load balancer to achieve the proper blinker speed.
There are no uneven gaps anywhere in the space between the turn signal and your OEM fairings.
