Curious how do you guys position your right hand so that the brake lever is always covered with 2 or more fingers and the wrist isn't too far rearward that you inadvertently roll on the throttle. Initially I adjusted the lever so that it was parallel to the ground but I have found and read that this would put a lot of stress on the wrist. So I rotated the lever down to its original position and adjusted the lever to the second or so position so my short fingers can reach. Would some aftermarket levers help? Do most aftermarket levers provide better ergonomics than oem?
