Hello guys,
Finally I put together my motorcycle cosmetically and took it out for a test run... ... Seems like there is something electrically not right.
1. If I push it when in gear, and take the rpm to approximately over 9, it starts loosing power... seems like power is being broken down into pieces. When this happens, the meter also shuts down, and instead of speed its like 000 or nothing, then again 000 or nothing..
2. The head light fuse keeps blowing up. I replaced it with 15 amp, but then again it blows up.
I did not do anything electrically after I got it back (it was stolen)... however; I did put in scorpio alarm (I do not think it should do that though).
If it helps, it also has a dino jet PC.
No idea why is it happening... is it that the generator is not putting out controlled output?
Please HELPPPPPPPPPPPPPPPPPPPPPPP
Thanks.
Thanks.
