Hey guys. So I just bought this bike and Ive discovered a couple problems.
1.) The bike cuts out under load ( Very Bad ) It breaks up and has no power
2.) When a rolling on the throttle quickly it breaks up immediately .
If your just driving around it runs fine. As soon as the bike calls for more powerthe problem arises.
Bike has NO MODS .. Is bone Stock ... It did have a cheesy slash cut 6 inch pipe that was taken off and when the stockers were reinstalled the servo cables to the butterfly was no longer availablee to reuse so the butterfy bracket is no longer on the mid pipe so the flap is just inside loose with no spring to keep it open or closed. this the problem ?
At this point i should just pry it out and weld up the holes correct ? Would JB weld suffice or go to my local welding shop .. ?
ALSO .....There are no Codes ... So that rules out a sensor correct ? ... Spark plugs perhaps ?
