1 - 5 of 5 Posts
So i installed a bazzaz with qs and TC .. the bike started first shot and run perfection except that the cpu is doing clicking noise. I swap it with my other 04 and still doing it so its not the cpu the problem...
Anyone have a clue of what it could be?
The cpu cant click it has to be the realy box on top of the ECU. double check all your connections and go from there. Remove what you have installed and reinstall one by one to see what is causing the problem. Then let us know and well see if we can figure it out.
ps is the exhaust servo hooked up? they can click when they dont have cables on them.
nah it has the servo buddy thing ... i checked again and its the relay.. ill check everything again... and see with bazzaz if i dont find anything !
removed the bazzaz. and its the ecu ou fuel pump relay.. only thing new on the bike is the battery.... good thing i checked now since the bike was going on dyno in 2 week... now need to find the F*ck... !!
1 - 5 of 5 Posts
