I have a 2008 zx10r that flipped in a lowside crash. The shifter and linkage was bent but both were replaced.
I am having trouble downshifting in all gears except for 6 to 5. I have to use my foot to slightly lift the shift lever before downshifting while moving. So to downshift, I have to pull in clutch, lift shift lever slightly, and then push it down.
I lubed all the shifter pivot points and double checked the clutch tension.
Up shifting is no problem. Any ideas?
