Ok, so bare with me while i try to explain what is wrong. And I am pretty sure this is some easy fix that will make me feel dumb... anyway...
I have a '11 zx10 that I am converting to a track bike. I stripped all the factory bodywork. I kept the TOS and have it mounted where the exhaust valve servo was (servo buddy in place). The TOS is mounted in the correct position. I also installed the Woodcraft keyswitch eliminator. After I installed that, I verified that the ignition turned on and that the bike would start. Ran it for about 4 or 5 min at idle, turned it off and took a lunch break. Went back to it and removed all the stock lighting and passenger seat lock. Then I modified a top triple clamp piece to get rid of the empty hole where a keyswitch should be.
Then the problem started. I went to start it back up again to lube the chain I cleaned the day before and it wouldnt start. When I turn on the kill switch I hear the fuel pump run and prime like normal. I press the starter button and I hear the starter relay click once very loudly and the starter motor wont engage. I thought maybe it was a weak battery, so I picked up a new lithium ion battery (wow that thing is light). Pop it in and same exact issue.
I used a circuit tester hooked to the negative battery post and checked the starter side of the relay when trying to turn the motor over and confirmed it is getting power. Lifted the tank and traced the power wite from the relay to the starter and saw no kinks or frays.
I am stumped and pretty annoyed :dontknow: . Took a break to post this up hoping that someone has had the same prob and found a fix or someone knows what may be the issue. Thanks in advance!
