1 - 5 of 5 Posts
from what i understand the tre make the box think its in 5th gear all the time gives you more advance in lower gears and lower rpm range. the ign moduel changes advance all the way through, you can either advance or retard ign and if you really want to get trick you can change timeing on each cyl differently. then you also have over rev option.
Discussion Starter · #3 ·
I have a tre and have read how they both work I just wasnt sure if the tre would interfear with the ignition module. By the way they they each work I wouldnt think they would but I was checking befor ordering the module. Was wondering if anyone had experence with both.
thanks for reply
1 - 5 of 5 Posts
