1 - 4 of 4 Posts
I just got a Two Brothers slip on for an 08 ZX10, and Im getting ready to install a Power Commander. I went to the DJ website and didnt see a MAP for that slip on. What do you do if there is not a MAP for a specific pipe?
Thanks
Joe T
There's a couple options available for ya.
1 use another brand slip-on map as a base and if necessary have it adjusted.
2 a PC is not absolutely necessary when using a slip-on as the OEM ECU can adjust within certain parameters so my suggestion is to try it without the PC first and perhaps even some dyno time to get an A/F ratio and then if the results indicate a need for the PC then have it installed and tuned with it.
Thanks
Joe T
I used the racefit growler map and I have an area-p slipon It seems to be working great.
Banned
Thanks
Joe T
I see a map for 2 Bros slip on on DJ's website for the 08 10R. Look again it may have just poped up.
JJ
1 - 4 of 4 Posts
