1 - 12 of 12 Posts
Hello My Dear Friends.
So, i recently got my 2012 zx10r. And i'm very happy with my decision and that move.
We are having a wonderful time and it's just a pleasure.
I went to my mechanic and he recommended me to get a power commander as i have an m4 street slayer exhaust installed.
Do you guys use PC on your bikes? Is better for the engine to have that device connected?
Is there anything i should know about it from you? ;)
Have a great day!
Mike
Don't bother with it. Just get it flashed by archer and get him to load a slip-on map. Look archer up on this forum, he's associated with Woolich Racing. Power Commander was useful back when nobody could connect to and modify maps bike's ecus. Nowadays, your bike included, it's all done without a power commander. That's not to say you can't put it on. You can, but it's absolutely unnecessary.
You may want to look into super bike unlimited, flash tune, and Nels two wheel dyno works for ecu flashes as well unless you are comfortable tuning yourself. IF you can tune yourself go with woolich.
Archer, does not flash anymore, he just sells the woolich.
buy the woolich, install one of the maps from map share, as a good baseline. and then tune.
I have some good maps I can help you also...
power commander will not make your secondaries open 100% and your ignition... the woolich does.
:+1: on woolich racing tune/flash.. so much more you can do with there software than a power commander. :rockwoot:
Apologies for the noob question but to tune a Woolich on from a baseline map does one need the Log Box or can the basic kit do it as well? I am leaving dyno tuning out of the equation.
No you don't need the log box. The log box is really only for the autotune which also requires the zeitronix zx-3 wideband 02 sensor.
Check this site it explains the packages... also if you go through zx10archer he does offer a slight discount for forum members! :grin2:
2011-2015 Kawasaki ZX10R
USB (Mitsubishi) v2 Package
2012 Kawasaki ZX10R ECU Flashing
also here is a forum post about woolich some info is older in this but answers many questions about it.
http://www.zx-10r.net/forum/f23/diy-ecu-flashing-woolich-racing-faq-165857.html
  • Like
Reactions: vroomshankar
1 - 12 of 12 Posts
