Hi!
After installing PVC & Autotune on my ZX10r 08 (european) and some acceptations of the autotune trims the bike goes better than before.
BUT:
Gear 1...4 are ok. Only with gear 5 & 6 and only in the low rev / low thottle area the bike starts to bog and shows hard load changes. it seems that the afr is to lean. it´s very dangerous to ride, especially in curves....
in this area autotune pvc adds up to 59% (!!) fuel, although in gear 1...4 there´s all in the minus ranges.
does anybody here have an explanation for this phenomenon :dontknow: or even better, a solution??? :+1:
below the gear based maps, i´ve marked the confused-area red.
Mods:
AKRAPOVIC - Slip On
AKRA Link Pipe with wide band sensor
cat's removed
Kleen Air System blocked
BUT:
Mods:
AKRAPOVIC - Slip On
cat's removed
