So the instructions said if using a PCV, to unplug the o2 sensor and use the bung. So I just unscrewed the O2 sensor and put the bung in and tucked the sensor up into the fairings. Is that good enough or do I need to remove it completely?
Also I didn't get a check engine light when I did the exhaust. I just pulled the cables off the exup servo and left the servo itself in the bike. I assume that's why.
