1 - 3 of 3 Posts
I installed my PCV and o2 optimizer a few weeks back on the 10R but the send map is always greyed out?
I have a custom map for a full system but isn't running to smooth so would prefer to run the correct map from Dynojet till mine gets on the dyno.
I have opened map it shows in the table but won't allow me to send it?
No errors show up on the PC software when plugged up, new firmware updated no issues...
On my 636 it works fine with bike just turn on not even running...
Is there a different trick on the 10R?
Open a new map from PC then you can send, when you first plug in PCV it will display map resident on PCV with nothing to send.
Done all that i opened a new map from the downloadable ones from Dynojet but will still not allow it to send stays greyed out.
1 - 3 of 3 Posts
