1 - 2 of 2 Posts
hi
I have installed Power commander and ignition module in my KAwasaki ninja zx 10 R 2009 I downloaded map from PC V web but I don't see much diff please also let me know if I have to install map into ignition module and if yes from where i can get them from. we don't have dyno tunes here In our country If someone can share one map of PCV and Ignition module ( If they are available)
I will b very thank full
here are the specs
AKRA Slip On
Kn&N Air Filter
Secondary plates removed
Smog Block Off plates installed
I know dyno tunes costs a lot out there but still I request someone to help me out
Regards
The maps on the Dynojet site are not very good. It will be best if you can find someone with a similar bike that has a custom map. They can email you the map then you can upload it to your bike.
1 - 2 of 2 Posts
