Please help... or recommend which map would be best to use
No, that would be pointless. The whole purpose of auto-tune is to build a map from scratch and adjust it to hit your specs. Downloading anything to begin with won't gain you anything. Start from 0 with it.Ooh, I was under the impression that the map is kind of a starting point, then the autotune adjusts it from there... but the better the map, the better it'll all run
