1 - 10 of 10 Posts
sorry guys, I searched the site over and could not find a definitive answer to a few questions:
1)Can the PCIII be uninstalled and your bike returned to its original settings by simply removing the device?
2)Can a map be downloaded with the stock settings or is all zero's in all fields, stock?
3) I have a 2005 ZX10, do I need to download the rough idle utility?
4)I assume this unit does not replace your existing ECU, but rather work in conjunction with?
I just got the Muzzy slip on and I plan to pick up the PCIII and use the DK slip-on map and DJ accelerator pump utility.
thanks
1. Yes
2. The instructions that come with the PC will answer that
3. Dunno
4. Yes
5. Moved
thanks
1. Yes
2. Yes & Yes
3. Yes
4. Yes, it is a piggyback system that intercepts the signals from the ECU to the injectors, adjusts them and sends them on again.
Hi K10 ;if you can post your observed or measured results.
I am debating between the Muzzy slip on and the full system...I am favoring the full system so far.
Thanks.
Discussion Starter #10
Thanks.
I have not dynoed for any performance numbers. I'm happy with the sound of the slip-on, however having had a full system on my 9, I think a full system sounds a little better. Then again, it just may be me. I have only ridden it for a couple hours with the new slip on and it seems to be slightly more sluggish on the low-end but mid and high seemed fine. I'm sure I can further fine tune this with the PCIII when it comes. I went round and round on this topic and many may argue, but I just couldn't see paying that much more money for the full system on a bike that already has a lot of power (more than I need for the street). Knowing that I could fine tune (or leave it alone) the slip-on was enough to keep me happy. I got the Muzzy (stainless), carbon fiber slip-on from parts411 for 420 shipped. Half the price of the full system .
You have to ask yourself do you want an exhaust for higher performance or better sound?
good luck
1 - 10 of 10 Posts
