1 - 4 of 4 Posts
Ok I got a pcIII usb and ignition module. Installed everything, hooked it up to my computer ignition(key) off using the 9v battery. everything work as it should.
First night everything seemed to work perfectly. Using a supplied map took the bike out and it ran like a raped ape.
Took the bike to get tuned (the shop no longer does it, long story) so I brought it home to play with a couple different maps. Hook everything up, plugged in 9v battery and nothing. No lights on pcIII, red light on ignition module.
The computer did recognize it as the Serial number displayed and it was able to read the map, but it didn't recognize the ignition module.
I brefly looked over the bike to see if anything had shifted no such luck.
Anyone know what going on?
Checked ground. don't see any problems there. bike still start and run like a top, but I am pretty that it is not working though.
1 - 4 of 4 Posts
