1 - 3 of 3 Posts
Hi everyone! i have a PC5 installed on my 08 10 and it works fine! I recently activated the Q.S function and installed a N.C switch for it. My problem is that at around 9,000 and up the bike cuts on and off at full throttle. I dont believe the switch is being activated as i am holding the shifter down with my foot to insure that its not. also when i do go to shift it, it isn't killing the engine at all. I do believe the switch is adjusted rite as i hear it click just before it hits the gear. any suggestions? do i need some type of resistance inline?
Discussion Starter #2
well thnks for all the feed back :^), I think I figured it out! Since I have a pc3 with ignition module laying around, I just plugged it in line after the pc5 and just used it for the Q.S. It seems to work but wont be able to fully test it out until we get some warmer weather!
Do you have a quickshifter expansion module or a sfm... You need to have either one for the quickshifter to work with the pc5
1 - 3 of 3 Posts
