1 - 3 of 3 Posts
Looking at getting a PC3 for my 07 after being persuaded not to get the two bros juicebox.
It says it comes with a preinstalled map for the 07. What would be the changes between the 2? Or is that the same as stock, then just download different maps to trial and error it?
Adam
Get it custom tuned. The downloaded maps are hit and miss and mostly junk in my opinion. If you don't plan on getting YOUR bike tuned with YOUR mods, then don't bother installing the PC. And if you look at the map in the software and there is any number other than zero in the entry fields, then it's not a "stock" map. I'll assume the preinstalled map is just some base-level swag at fueling numbers which probably won't work very well for you.
1 - 3 of 3 Posts
