1 - 11 of 11 Posts
You can connect in series a PCIII USB with the PCV.
The PCIII USB will be loaded with a zero map.
So now you can connect the ignition module to the PCIII USB.
It seems strange and complicated but it works fine.
There is not such delay at the signal that may cause problems.
so your saying in order to control the ignition timing on a PC V equipped bike someone needs to run a PC III and then a ign mod?
so they DONT offer a ign mod for PC Vs?
I don't see why it is taking so long... they already have the technology with the PCIII version, and a company like that should have the resources with no problem to adapt it to the newer bikes. Either we are missing something or they are dropping the ball completely. I have an 08 and the reason I went with the III instead of V is for the ignition module.
1 - 11 of 11 Posts
