21 - 40 of 236 Posts
Hoser said:
thanks for the map. looks pretty good, might be a bit lean for me in a few spots on/off throttle but i'll give it a try.
my mods are yoshi trs bolt-on, K&N, TRE (gi pro) so its good for my setup, just not sure about elevation. im at 1100 ft here.
I would say that this map is 2 rich for you at 1100 feet...
The map I posted above is a richer version of the dan kyle tre sato slipon map... I used the sato slipon map with the stock exhaust and the BMC filter and the bike ran HARD ! The throttle is very crisp due to the leaner mixtures but I would not use it at higher elevation... Who knows for sure - I don't have an o2 guage hooked up to verify if it is too lean but it still felt good.
Try the other map, and if it seems to bog, try this one instead:
dan kyle sato slipon map
(user submitted map off the dynojet site it wasnt done with the TRE)
Lastly, don't forget to set your TPS range in the power commander.
You can do this easily by installing the 9v battery to the pc3, then use the tps utility to set the TPS range.
Good luck !
My engine spun a bearing so i swapped in a stock motor into my 05. The original motor had a MAP for my degreed cams and thin HG. This MAP has triggered my FI light and it runs pig rich. I need a MAP for my EVO2 for a stock motor. I had Ivan's Map originally but didnt keep it in my files. so i'm starting over from scratch. I didnt know how good the Map on Dynojets website was but i need a decent off the shelf map before i get it on the dyno later this summer. I don't run the TRE btw. Thanks!
Here you go enjoy!:zx_blue:
MIA Ex-Mod
POSTED FOR Nite-ryder
Here is a custom map that I had done this weekend. I have an '06 ZX-10 with Yoshi bolt-ons, BMC air filter, disabled butterfly valve, KLEEN block off plates, and gutted cats. I am running at about 4500 ft. elevation.
I think you're still puttin' these out!! Hopefully someone can benefit from it.
Thanks...
Nite-ryder
MIA Ex-Mod
POSTED FOR SalKhan
Just wanted to throw a custom map your way. This map is for 06 (and I’m guessing 07?) ZX-10R’s with A&R Motorsport Race Baffles and BMC Race Air Filter.
Everything else is completely stock!
Hope it helps!
SalKhan
POSTED FOR blackisfaster
For 2006 ZX10R:
Posted this in performance and tech: and the pc map posting thread is closed, so I will post this here. It is a map for an A and R race baffle kit with a BMC street air filter. Hope someone can use it; and if anyone tweaks this and makes it better please re-post. Peace :cool:
MIA Ex-Mod
Posted for Older Guy Bazzaz Maps
There Bazzaz maps are for a 2008 ZX-10R with a flow through Area P full exhaust system.
The Apex 10-24 is for a dyno run and auto tune
+5 is to clean up some rough transition from off throttle to on throttle.
+10 is same a bit better...
Older Guy
Hello everyone! Im looking to see if anyone has a custom map for an 08 ZX10R with a moto gp slip-on, k&n filter, and block off plates. The one i downloaded off of the website made my bike run lean at about 80mph on full throttle. So if anyone has anything for me post it up or shoot me a PM. Thanks everyone!
Looking for a Map for a 2008 ZX10R with a PC-V and a Akropovic slip-on
I just installed a Akrapovic slip-on and installed the PC-V. I have no exhaust valve installed. The bike is popping when decelerating really bad. I can not seem to find the right map for the bike. Hope someone can help.:sad:
07 10r full muzzy, k&n filter. any maps?
Hello, friends! You have a very cool forum, lots of different information.
I have a kawasaki zx10r 2006. Face slip-on akrapovic + removed exup + catalyst is removed. The exhaust system I have now fully co-current. And as I put the filter k & n.
Fuel controller I have put Bazzaz.
Are there any ready-made fuel map for this set, preferably those who are tuning in to dino booth?
From Russia with love, respect, Maxim
looking for a zx10r 2004 pc3 map with stock exhaust, kn street, exhaust servo eliminator, secondary butterflies out and block off plates. Someone help!
Ok I'll try here....
Lookin' for a map for a stock '07, K&N with A&R baffles (nothin' fancy).....
Something for a PCIII to make a difference?
Thanks!
(no, it's not my bike) :)
Anyone messing around with PC V maps for 2011 Gen4?
I have to learn more about doing the mapping, any references to read to help me map would be appreciated? I think if I can find a decent map for it, it will just rip.
need advice on map
06 zx10r , yoshumira r22 blings bolt on , just ordered a healtech gipro with atre , advice on map if needed
