Stripped bike down to do a transmission swap... 5th gear went out on me... Got everything bolted back up, motor back on the frame, and all connectors are in place, PC III hooked up and grounded.
I turn the key, turn on the ignition... No Lights on the PC III, motor turns over but, never fires. Put the battery on the charger thinking that maybe this could be the issue. Put battery back in, turn the key, turn the ignition, PC III cycles, bike fires up and runs for 5 minutes. I turn it off, turn it back on, no power to the PC III... Turns over but, won't start.
What the hell is going on, bike ran fine besides the trans... Took motor off to rebuild the trans, put motor back on, plugged everything up, ad now this... Need help bad.
