1 - 20 of 55 Posts
Stopped by Mach One in Costa Mesa, CA - they had a ZX-10R they were going to put on the dyno and map...they had the fuel injection all apart and had removed one set of butterflies...they said that is one of the things they do when they do a dyno tune and re-map..anyone heard of this?
MIA Post Whore
The Gixxer crowd, at least the ones I know, claim to get some HP from removing the seconday butterflies.
Older Guy
Do they remove them permanently or just for tuning purposes??
Big Daddy said:
Older Guy
The impression I got is that they remove them permanently...they had a 4 page list of itemized things they do for the ZX-10R dyno tune and remapping...
MIA Post Whore
So share the list! Do you know anything else that was on it?
Also what were the results, did you hang around to see if it worked?
Guess if I make some good commissions next month, I'll have first hand experience....figured I might have it done to mine in February...
Discussion Starter #8
The bike was all apart getting it ready for the dyno tune and mapping. It is a full day job. The injectors were all apart - rods out, butterflies out, etc.
Wow, you're talking about me and my bike! I just joined this forum 5 minutes ago and this is my first post.
I realize that I'm new and don't have any credibility in this forum yet, however, you asked for it - so here goes...
The secondary throttle valves and the exhaustpipe valve are polution controls that rob the engine of power and throttle response. They have no other purpose. In order to effectively remove them, you have to:
a) install a full exhaust (Arata in my case)
b) remove the secondary butterflys and shaft
c) do a custom map with a Powercommander
The result is more HP and torque at all throttle settings. Richard at Mach1 knows exactly what he is doing. He did all the engine work on my 04 R1. I trust him completely. When he is finished, I'll have the best running ZX10 around...
jack
Discussion Starter #10 (Edited)
Hey Jack...welcome...Richard is the tall MoFo that does the dyno work in the back?...they walked me through what they were doing on your bike...however, be forwarned...black is the fastest color...not puke green...I saw them drop a small nut into one of the throttle bodies...
They were telling me you got a real good deal on that bike with only 1,900 miles on it...got it at Champion, did you?
Just because I'm a newbie could someone shoot me a pm on how to remove the secondary butterflys and shaft or explain how it's done?
Im new to the zx-10 as well. Do they remove them just for the California models, or do all zx-10s have the same pollution components?
being a newbie has nothing to do with it, i don't think this has really been a debated topic....so if anyone knows how or what to do...post it.....also if there are any dyno's post them too...thanks....
p.s. merry christmas all
MIA Post Whore
My suggestion would be to follow the manual. But... from the looks of 'em, the upper butterflies come off by removing the two screws holding each one to the rod. If you're only planning to experimeriment leave the rod in place. My gixxer buddies who removed theirs removed the throttle bodies, filled the holes left by the rod removal with JB weld (or simular) then smoothed the patches with a dremil. They swear by this mod. I'm a bit nervous. If done, get a custom map. (imho)
Discussion Starter #15
And...Jack....when you go pick up your bike, how about getting and posting that 4 page list and the dyno chart...
OG Post Whore
sofa-king-todd-did say that in english
Welcome to the site, let us socal guys know how it turns out and if you dont mind how much they are charging you to tune that bad boy. I was thinking of taking mine down to the Ducati and Aprila of Oceanside since they are the only ones around me with a dyno, but if you get as good results as you say you are expecting they may be worth the trip.
Secondary throttles
The secondary throttle butterflys are controlled by the engine ECU. Their purpose is to produce better midrange power at large throttle openings. They are fully open at high rpm. The Suzuki 1000cc race motors, that are not required by any racing rules, remove or disable them for racing use. You can do the same on the ZX10R engine. If they are removed the typical increase is 2 to 3 hp above 10,000 rpm due to less air flow resriction in the throttle bodies. If they are disabled the throttle response is better above 10,000 rpm when transitioning from closed to wide open throttle. Low and mid range power will suffer below 10,000 rpm at large throttle openings and throttle response is poor below 9000 rpm. This modification is for engines that operate above 9000 rpm and throttle response below 9000 rpm is not an issue. This modification is for race engines. A street engine suffers from this mod. You also need the Kawasaki race ECU and a load control dyno to remap the fuel curve for this mod. You could do it with just a PowerCommander but it would require a lot of work. The factory teams use the race ECU and a PowerCommander.
I am sure there is some street squid out there that is going to try this and complain about the results.
How much time do you spend at 100 % throttle above 10,000RPM?
1 - 20 of 55 Posts
