Update* Sold bike whole.
Does the Fairing set include the tail section?
Thanks
No, that I don't.Do you happen to have a Rifleman insert?
Worth a shot, I was hoping you forgot to list it with so many other parts :smile:. Thanks!No, that I don't.
I hope this helpsDoes your Akro header have an exhaust bung steady on it ?
Do you have the shift arm for sale?Looking to part out an 08 zx10r I have. Clutch basket blew and bent the crankshaft, haven't been able to source a decent priced crank or a relatively good deal on a complete engine. So my next route is to just part out the bike. Prices are matched or below ebay prices. Bike has 20k miles on it. Ill try to include all the hardware for each item to be mounted. Shipping from Ohio.
Can also reach me at 409.299.3565
Parts for sale:
Full Akropovic Exhaust (shaved emblem) - 1000
Power Commander V- 250
Radiator w/fan - 120
Headlight - 150
Gas tank - 200
Fuel pump -70
Frame w/clean title - 1600
Left mirror - 50
Right Mirror - 50
Throttle Bodies - 100
Subframe - 200
Full Black Fairing Set (including bottom fairings)- 500
Forks - 250
Upper Triple - 100
Lower Triple - 50
Speedo - 200
Upper stay - 100
Lock set w/key - 150
Stock Ohlins Steering Damper - 100
Rear Shock - 100
Rectifier - 50
Full Left Clip on w/pazzo lever - 100
Full right clip on w/pazzo lever 100
Front Wheel w/o tire and rotors - 250
Front Brake Calipers - 100
Rotors - 70
Full Body Harness -50
Headlight Harness - 20
Front Seat - 50
Rear Seat - 30
Good Engine Parts
Complete head w/ cams and Ivan Smog Block off plates - 300
Complete clutch basket with clutch and friction plates (new but temporarily installed) - 100
Stator - 50
Starter - 200
Transmission - 150
*ASK ABOUT ANY OTHER PART OR ENGINE COMPONENT* I'll verify that I have it and if it's in good working condition.
I may have found a motor. If this is the case, I’ll have to hold off on selling anything else. I’ll keep you posted within the next day or so.Do you have the shift arm for sale?Looking to part out an 08 zx10r I have. Clutch basket blew and bent the crankshaft, haven't been able to source a decent priced crank or a relatively good deal on a complete engine. So my next route is to just part out the bike. Prices are matched or below ebay prices. Bike has 20k miles on it. Ill try to include all the hardware for each item to be mounted. Shipping from Ohio.
Parts for sale:
Headlight - 150
Gas tank - 200
Fuel pump -70
Left mirror - 50
Right Mirror - 50
Subframe - 200
Forks - 250
Upper Triple - 100
Lower Triple - 50
Speedo - 200
Upper stay - 100
Rear Shock - 100
Rectifier - 50
Rotors - 70
Front Seat - 50
Rear Seat - 30
Good Engine Parts
Stator - 50
Starter - 200
Transmission - 150
If so please pm me a price to ship to 18103.
Thanks,
Don
Parts for sale:
Headlight - 150
Gas tank - 200
Fuel pump -70
Left mirror - 50
Right Mirror - 50
Subframe - 200
Forks - 250
Upper Triple - 100
Lower Triple - 50
Speedo - 200
Upper stay - 100
Rear Shock - 100
Rectifier - 50
Rotors - 70
Front Seat - 50
Rear Seat - 30
Good Engine Parts
Stator - 50
Starter - 200
Transmission - 150
