1 - 2 of 2 Posts
Hi There, I’m in NewZealand and race an Open Wheel Lightning Sprint, have just installed a 2008 zx10r. Had an ECU flash done then onto dyno for tuning, for some reason a sensor is telling it that it needs more fuel than necessary, fuel pressure set at 43psi but far too rich, went as low as 28psi and ran spot on , but this is risky as it may lean it out at some point if the the sensor decides to work.
Ha anyone encountered this or can someone help.
cheers Andy.
Did the flash turn off the O2 sensors? Are you using the MAF sensor?? from original air box? Reset the fuel pressure immediately.
1 - 2 of 2 Posts
