1 - 20 of 39 Posts
Going to the dragstrip. What is the optimum rpm to shift?
Other than first to second. I expect I might need to short shift that one a little.
Also, do I dare hold the throttle pegged & fan the clutch, or am I inviting a big skyshot?
Banned
I would blip the throttle and shift while you blip it, Full throttle power shift, it is way more consistent than trying to fan the clutch every gear.
If your foot shifting then just above redline if your using a stock gauge for the other gears.
If your stock wheelbase then yeah your asking for BIG trouble...depending on your experiance and gearing 7k is a good start and go from there.
One down on front (16 tooth)
Stock length. No lowering links ( ordered but probably wont make it in time)
I am most concerned with the first to second shift regarding the big wheelie.
Does the power climb right to redline or does it level off? I haven't had a chance to dyno it yet.
Please say you atleast have a strap for the front???
Shift at redline!!! :helmet:
Discussion Starter #8
QUOTE]
Yes. :mrgreen:
I was under the impression (from searching threads) that maybe I shouldnt pull the front down if I didnt lower the rear.
I expect I should loosen up the rear preload and put compression on minimum & rebound on max. Correct?
I want to do my best to let the Ninja shine:thumbsup:
QUOTE]
Yes. :mrgreen:
Strapping the bike is for the strip only and will be fine with stock rear height. I'm not saying not to go without a strap, but it will be pointless. I wouldn't worry with susp. settings. :thumbsup:
Discussion Starter #15
Is that a stock bike?
Looks like she pulls pretty good right up till she hits the limiter.
Thanks.
Had mine dynoed at a local bike show, and it pulled almost all the way to the redline. I would have to say the optimum shift point would be at that point. Lower and strap that mo'fo'!
I have mine lowered 1 1/2" front and rear and it sticks very good. No strap, and just street tests - no strip runs.
And if its a 04 05 without a strap, get ready for some really, really good headshakes when shifting... they'll keep your balls in check for sure. :eek:ccasion1 :moped:
Discussion Starter #19
So the strap will act as a damper (sort of) right?
On my ZRX , strapped or not, it has never given the slightest hint of headshake. But the little I've ridden the zx10, though it hasn't happened yet, it feels as though it could happen easy enough.
Get a Raptor shift light (this will help your shift point consistancy alot) set it 200 rpms before the rev limiter-not the red line-and you will be hitting the correct shift point. This made the biggest riding difference for me on my '04. Google Raptor shift lights, they are not exspensive and really work well, install instructions are on the site. :mrgreen:
1 - 20 of 39 Posts
