1 - 20 of 27 Posts
Ok time to get into drag racing!
I'm brand new to dragging but has been around nothing but drag racing. I road race a lot meaning roll ons on the highway and what not but has NEVER drag raced.
So I got this 04 I can use to drag and I was practicing launching last night and I'm trying to leave at around 6k as I launch the bike seems to bog should I launch at higher RPM's like 8k like most people say? I'm a lil worried about that since I'm SWB and never launched hard before.
Its an 04 SWB with full Akra, pc3, Scotts damper lowered ummm A LOT! -1 front. I weight about 150 with gear. Also during drag do you guys use clutchless shifts or no?
Any suggestions or advice? I plan on doing a 2' or 3' add to the SWB. Didn't want to go to far since I didn't want to lose that much cornering. Getting my gears undercut, and installing cams and shift star also during the winter.
Clutchless shifting when drag racing.
I've got a quickshifter that'll plug right into your PC3 - kills the ignition rather than the throttle so you can shift wide open throttle if you want. $100 to your door.
FEELING LUCKY, PUNK ?
use your clutch and you add 3 seconds :thumbsup:
Just stretch it 4-6 in. then launch the hell outta it ... Then shift as fast as you can without the clutch just a small blip of the throttle ... See what you get.
So you guys don't think I can get away with just a 2-3 inch stretch? Yes, I know I have 4 bikes now BUT this 04 seems to be my favorite!
Using the clutch doesn't really add 3 seconds does it?
Me weighing 150 with gear what am I looking to get for my first run? 10.8's?
And lets say I got GREAT and to keep it SWB what should be the best numbers I should be looking at?
Thanks so far for all the input guys, I will keep you guys updated and post slips.
my 04 that i had for one month that was bone stock i went 10.15 first time out stock ride hight, stock gearing and wheel base. got stolen 2 weeks later. now as for my 05 i have gone 9.3 foot shifting with kawi race intake cam and thin head gasket -2 and plus 2 in the rear. i still could go faster but havwent had any good luck this year with the new setup dam big bores
damn -2 in front? wouldn't it be easier on your chain if you went -1 and +5? What's your top speed with that set up you think? 160ish?
yeah but i had the 15 and just put it on not sure what top speed was i put the 16 back on to ridr the street only stakes a few min to change them
Discussion Starter #11
You were the one that mentioned the Robinson gear right? I could not find a site for them.
Discussion Starter #13
Schnitz Racing has it but it makes a lot of noise. :thumbsup:
but is it worth it? I'll deal with the noise if the gear is strong and will hold up.
i bet that gear is stronger than the stocker i loved mine
You should be able to do 10.5's easy at your weight with stock ride height. Lowered u should go quicker. -2 in the front isn't that hard on the chain. I weigh 210+ with gear and I've gone 10.03 with swb. Track time makes the most diff. though, test and tune days rock. Just let it cool down a little between passes.
inappropriate
damn jblaze, your light weight at 150lbs you can be a horse jockey
you have 4 bikes make this one long. :thumbsup: Keep the clutch fibers soaked good and leave around 7500.
:+1: tilt the bike steeply to the right to lube it up good just before launch
no, not really. maybe 3 tenths
inappropriate
whats so good about the shift star?
Yeah Im sure its stronger than the factory one. Its just that the pitch on the teeth is different to allow for the different tooth count and its really loud mostly on decel and only in first gear. if you can put it in yourself its really not that expensive. On the other hand if you have to pay someone to do the work its alot of money for a small gain.
I lowered my bike 4" with stock gearing and ran a 9.6 at rockingham. I got some lowering links, and a lowering strap from Lee's performance for a little over $100. With the lowering links you can go stock, 2", or 4".
Keep riding it SWB it will teach you clutch and throttle control when launching. SWB riders are some of the best in the business...
1 - 20 of 27 Posts
