1 - 4 of 4 Posts
Thats exactly the leak I had about a month ago. Just needed a new valve gasket (part # 11061-0223) I had my local shop do the job and at the same time check the valves for clearance. Took them about 4 hours but everything is good now. No more leak. Now I just got to get my ECU installed.
Generally you don't want any gaskets leaking anything. But sometimes that kind of gasket that seals the valve cover can get hard and let oil seep by.
BigCat for Prez!
very normal leak, just needs new gasket, and possibly valve job.
1 - 4 of 4 Posts
