1 - 20 of 26 Posts
what makes oil go in the airbox, whats the fix other then putting a catch can from the case hose to the air box??????????
Didnt start untill i put a head\cam on my bike not alot of oil BUT some oil:dontknow:
welcome to 10's once you start making power you have this problem its perfectly normal just run a catch can and empty once a month or every 2 weeks
yup, blowby,wheelies,over filled(high oil level)....those are the options.
it's been doing it for years i just hate it, there is not any good place to put a catch can, pic please
I keep my oil close to the bottom line, I was filling up the site glass lol I found out thats to much oil,lol
Good to know it's a common problem:badteeth:
Discussion Starter #8
:thumbsup: thx guy's
If you have the 04-05 race manual, check it out, Kawi actually sells a catch can for this.
Discussion Starter #11
Tasos, where you been i hope all been well:thumbsup:
Discussion Starter #12
I dont have one but im going to start looking thx:thumbsup:
I had the exact same issue. I ended up changing out the tiny filter the is in the back of the airbox and that fixes the issue up for a handful of months.
I now just swap out that filter every second oil change (Street ridden bike).
Custom Powder Coater
Is this a problem on the Gen3? I just capped off the airbox, and put a filter on the tranny vent. I haven't ridden it yet, but this sounds like maybe a bad idea to not have the tranny vent going directly to a container of sorts.
So how can it be cured (blowby)?
My oil relief valve was stepping and i changed it.
I measured 40KPa? (double) oil pressure before changing it .
2mm overbore Je's with stock head.
It lasted fine on the dynapro though (20hours)...Saw it after.
Is this normal?
Any suggestions, thanks :thumbsup:
Does not drive into smoke
Does it also happen when the engine is hot? Maybe there is simply too much clearance between the piston rings and the cylinder walls...
You could also install an oil separator and a return hose. :mrgreen:
And good to see you back here. :eek:ccasion1
Yeah but we are talking about ALOT of oil, up to the stacks.
Isn't excessive pressure hurting things inside the engine? Maybe a bearing ? :eek:ccasion1
1 - 20 of 26 Posts
