1 - 20 of 46 Posts
My new tuner told me to NOT use K & N oil filters that they are inferior to stock filters.
I use K & N because they are so much easier to install and remove...
Any comments from you guys?
The best filter out there is the Purolator (PureONE) part#PL14610. It's the same filter that's on the ZX12, ZX10, ZX636 etc. We spent long many hours debating this on the 12R boards & done tons of research and comparisons to find the BEST of the best filter. This filter strains out the smallest particles and has a Anti Drainback check valve, and more pleats for greater surface area.
Not saying that the OE filter is junk, but it's made by a company that's NOT anywhere near the top of the list for the highest quality filters. It meets the factory specs and that's great, but there are much better filters out there.
Also I'll say this a larger better flowing filter will give you free HP. It's worth 6 to 9 HP on a 500" PS motor. This is because the pump don't have to work against the restriction of the small filter thus allowing the motor to spin more fleely. = Free power
So just think about how much a stopped up dirty filter cost you.
OH! and best of all the PureONE is about 6 bucks compared to the Stealership model being 12 or so.
I have always either used stock or K&N with no probs. I jsut recently bought the Pure One brand filter, I got mine from Pep boys. I cant remember the number right off of the top of my head though.
I buy the Mobil M108 and M110 at Autozone for about $11.
The PureOne is a great filter as well, just not readily available in my area.
Discussion Starter #10
My problem is can't find a wrench for the stock filter - as is why I used the K & N.
Pep Boys nor does Cycle Gear have a filter wrench that small.
I don't like trying to punch a hole in a filter with a screwdriver to get it off.
hit up your local Honda shop and see if they have the cup style tool, one that fits over the end like a cup and a 3/8" drive.
I bought a set of channel lock brand oil filter pliers from my tool guy. They are set up just like a channel lock just with jaws for grabbing the filter with. pretty handy.
Discussion Starter #16
The smallest one of those Pep Boys carries is too large...
Oh no OG you don't have to punch any holes. I am sure you have much more experience than me...but just warm the bike up a bit.
Let it set till the pipes don't burn you and spin it off with your hand or (almost) any standard filter wrench.
The key for me has been to have the motor warm prior. Have you been doing this????
Banned
zx10ragentorange said:
I only use OEM filters as I have heard that other ones are not as good
:+1:
I've never used anything other than OEM filters on all my bikes. I don't trust K&N, or anyone else for that matter, when it comes to something so important. On top of that, I have also heard negative things about K&N's oil filters.
:+1:
I don't remember where I got mine, but that is what I use. Also, don't know what your thoughts on the subject are, but if you are torquing the filter to factory specs, try just tightening it a turn or so after the gasket makes good contact with the engine. I think the factory torque spec for a filter is crazy.
:+1: I am using the same one I got from Honda for my RC51.
1 - 20 of 46 Posts
