1 - 10 of 10 Posts
I just picked up a Ohlins TTX EC and was wondering if anyone has put the hydraulic preload controller somewhere else than the default location? I'd like to pull off the rear pegs, since they aren't being used for anything.
you can make a aluminum L shaped bracket and mount it too the 6mm bolt holding the rear hugger on then drill a 8mm hole in the L bracket to mount your ttx 36 bracket on too, use a alloy polish to clean up brackets and they look trick
Thanks for the posts! I liked the under the seat idea and decided to do it yesterday. As you can see I used a zip tie to just hold it in place. Is a wire tie sufficient or do I need to secure it down with a bracket?
1 - 10 of 10 Posts
