1 - 5 of 5 Posts
Will a 06 Ohlins rear shock fit a 05 zx10r? I tried to find out myself but failed.I just may sell it if it does not fit.Heres some pics with some numbers on the shock.Thanks.
That one should fit. You might have to adjust the preload bracket, but it should bolt right on. Check the overall length though. You'll probably want 3 or 4 mm longer to start with.:thumbsup:
I may take the time to try it out.thanks!
1 - 5 of 5 Posts
