1 - 20 of 22 Posts
For the guys that been running that semi-active e-shock for a while.. Is it that big of a difference vs a shimmed stocker or just all hype?? Been reading all the mags reviews.. they all came up with different pros and cons.. argh!
My experiences so far, coming from a modified stocker to the mech.:
1.)Install is easy, basic hand tools, no permanent modifications to anything is required.
2.) Adjusting the preload is easier now with the remote adjuster. I Love that.
3.) The changes in the suspension are not noticeable. I guess it adjusts pretty smoothly, because once I was out on the track, I completely forgot about it. That's really the best compliment I can give a shock.
4.) There is a hint of not not enough rebound dampening in the shock at race pace. It wasn't noticeable at my old pace, but as I picked up speed, I did get a little wallowing feeling from the back exiting the turns like I did with the stock shock before I had it modified).
Overall, I would say this shock is perfect for the street/track rider who wants the best of both worlds. For racing, I love it because I don't have to tinker with settings, trying to find the right dampening. However, I suspect that eventually I will outgrow the dampening characteristics of the shock and I will be unable to adjust it as far as I can tell. That is at full-blown race pace on slicks though. I just love the plug-and-play of it though and can't stress that advantage enough.
The stock shock as it comes from the factory needs help. You can get it re-sprung and re-valved and it will work pretty good, but in stock form it is not up to the task of race track duty.
My recommendations:
If you ride street and track regularly, get the Ohlins Mech.
If you want better street riding only, re-spring the stock shock
If you want improved street riding and occasional track, modify stock shock spring and dampening
If you ride mostly track/race and know what you're doing with a shock, get a regular Ohlins shock.
If you ride track only, but suck at adjusting suspension like me, get the Ohlins Mech.
I plan to use it for the first time at Road Atlanta this weekend. I'll report back how it feels.
Thanks a lot for the replies! :eek:ccasion1 I bet a lot of people here are also interested and curious about this rear shock.. Brillant..How was your week-end???:dontknow:
I really, really like this rear shock. A picture is worth a thousand words so here are the equivalent of three thousand words...three pics of the rear tire (Bridgestone R10 DOT Race) after two full days of riding NESBA A group at Road Atlanta. Granted, RA is not the most abrasive track, and I'm no Dave Moss, but that said, I can't imagine how the tire wear could tell a better story. I love being able to set the sag and let the chip take care of rebound and compression. Later this month, I plan to track the bike at a track known to be more abrasive on tires; if there's any difference, I will report back. Meanwhile, as I've noted elsewhere, if it's good enough for Ken Hill of YCRS, it's good enough for me.
Brillant! that looks awesome! good idea with the pics.. I will probably pull the trigger on this one!:eek:ccasion1
That's awesome! I was looking at one but still not sure yet. They just plug in to the ecu?
Yes, it plugs into the diagnostic port.
Gradually dialing in the bike. I was at Barber yesterday and recorded my personal best time...broke a 1:40! Woo hoo! Not knocking the regular TTX shock, but it's just nice to know that I don't have to mess with the shock settings once I set the sag. That's a real bonus especially when you move from track to track or even the same track that gets resurfaced from time to time.
Where is the cheapest place to buy these from? I really didn't think they would work that well but seems like all positive reviews.
I loved mine until it was destroyed together with my bike. It transformed the G4: precise and predictable. Recommended.
A.
There is no compatability issues with this shock (that plugs into the ECU) and having a reflashed ECU? Would I have to do anything different if it is compatable? ABS no problem either?
All good. Reflash and/or ABS, not a problem.
1 - 20 of 22 Posts
