1 - 3 of 3 Posts
I have an Ohlins 30mm Cartridge kit that I am no longer going to use. This will take me a few days to ship out since they are currently installed in my forks. This is just the 30 mm cartridge kit and a 2 springs. I have 2 1.0's and and one 1.05. You pick which two you want. Ohlins TTX Shock is a KA036 model with a 115 spring on it. Shock is still on the bike as I am waiting for the new one to arrive. If someone buys the shock before the new one arrives I will pull it and send it the next day. Just leaving it in right now so I can move the bike around the garage if I need to.
Ohlins 30mm cartridge kit $old
Ohlins TTX $old
115 is the spring rate. What spring rate you need depends on rider ability, rider weight, intended use, etc. You would have to check around to see if a 115 N/mm spring is right for you. If its not you can easily have the spring swapped out.
1 - 3 of 3 Posts
