Ogio continues to set the standard for high-quality motorcycle gear luggage with the Trucker 8800 bag. Measuring 15” high x 18” wide x 32” long to deliver 8,800 cubic inches of space, we found plenty of room within to store all of the typical riding gear. The entire chassis is fabricated from a tough 600D PVC/Tarpaulin fabric that will continue to look good after years of service. The Trucker 8800 is built with oversized wheels and a telescoping boom so you can easily roll the bag over rough terrain, or if you prefer, use the included shoulder strap to carry the bag over unsuitable surfaces. A large U-shaped zipper allows easy access to the cavernous main compartment of which, on either side are found mesh pockets to help organize your gear. But this is more than just a motorcycle gear bag – use it when you travel with the airlines too! After all, Ogio guarantees their luggage for life so you can rest assured that even the most disgruntled of baggage throwers isn’t going to destroy this bag.
Ogio bags are the preferred brand of luggage for the entire RidersDiscount.com staff – to order yours, call TJ at 866.931.6644 ext 817 or, send an email to FORUM at RIDERSDISCOUNT dot COM with OGIO TRUCKER 8800 in the subject line, along with the color you want – Stealth (all-black) or Grangler, and we’ll get back to you right away.
The Trucker 8800 from Ogio in the Grangler color scheme.
We loaded this bag with a helmet, full leathers and boots and found there was still room to spare for a back protector and other riding accessories.
A separate boot compartment allows you to keep what is most likely the dirtiest part of your gear separate from everything else. Also, notice the large web structure that helps your gear from becoming stale during long term storage.
Also available in Stealth color scheme.
