The OGIO No Drag Mach 5 Backpack was created specifically with motorcyclists in mind. Its molded shell construction was designed to reduce drag while riding. Now it's available in two new colors: red and hi-vis.
Colors left to right: Stealth, Red, & Hi-Vis
In addition to its aerodynamic properties, the shell is also water resistant to help protect your belongings.
Inside the OGIO No Drag Mach 5 you have 1475 cubic inches of space for your gear. This full storage capacity is reached by opening the zippered expansion gusset around the back of the shell.
Organize you gear with individual pockets for a spare face shield, electronics, small items, a hydration bladder, and even your shoes. There is also a padded compartment that will accommodate most laptops up to 15”. An integrated, removable helmet carry strap is also included.
The Mach 5 carries your gear comfortably thanks to padded back panels and adjustable straps for the shoulders, chest and waist.
Reflective detailing allows you to be more visible to other motorists, especially at night.
Dimensions: 20.5" H x 14.5" W x 7" D
Weight: 3.7 lb
Capacity: 1025-1475 cubic inches
MSRP $179.95
If you have any questions about the product or would like to place an order, feel free to give MIKE a call at 866.931.6644 ext. 804. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM and we'll get back to you right away!
Weight: 3.7 lb
MSRP $179.95
