Ogio’s Baja 1650 hydration pack offers a unique combination of storage capacity for your gear while a separate compartment allows you to comfortably take up to 2L of fluid with you. The sleek, low-profile bag has adjustable shoulder and sternum straps for a near custom fit regardless of how it’s loaded and the side that faces your back is padded in such a way as to promote cooling by standing the bag off the skin just enough to let air through. A separate audio pocket with an outlet port allows you to easily carry your tunes with you while the main compartment has enough room for a part of sneakers and other gear. Mesh pockets on the flanks are ideal for items that you would expect to access frequently. Unlike other hydration bladders that require the user to screw on the opening, Ogio’s approach is slightly different with a sliding closure on one side that allows you to flip the bag inside-out for easy cleaning. Of course, this also makes it very easy to fill it up as well. The bite valve can also be adjusted for fluid output.
As with all other Ogio gear bags, these hydration bags come with a lifetime warranty.
You can read all of the details about this on our website or call TJ at 866.931.6644 ext 817 for more information. If you prefer email, send those to FORUM at RIDERSDISCOUNT dot COM with OGIO BAJA 1650 HYDRATION BAG in the subject line and we’ll get back to you right away.
The Baja 1650 from Ogio is available in “Grangler” (shown) or “Stealth” black colors.
