1 - 8 of 8 Posts
hello, new here.
i want to order the oem levers for my zx10 2016 (13236-0770, 46092-0565).
I'm not sure but on sites I've seen the brake lever does not come with this part:
i right? if yes, what the S/N of this part? I can not find it anywhere.
tnx.
I've never bought OEM levers but most aftermarket levers will come with the perch you are referring to. I would think OEM would include the same piece. However, I bet someone on this forum still has the oem levers that they have replaced and would give you a good price. Try posting in the wanted section..
'16 ZX-10R KRT
That highlighted tab area is for activating the brake light switch. It is not separate. There's no part number for that because you can't buy it separately. The lever is 1 piece. Aftermarket and OEM are the same way.
Discussion Starter · #7 ·
Thank you!
I was not sure because I did not see it here:
ttps://www.kawasakipartshouse.com/oemparts/a/kaw/56e7266d87a8660e60bbd7c6/front-master-cylinder
Tnx!
1 - 8 of 8 Posts
