1 - 5 of 5 Posts
When Downshifting, often (about 75% of the time) it will be notchy. The degree of notchieness varies.
Any Ideas?
regular shift, stock clutch going on 22k miles. Dont think i ever abused it too much. Fresh oil @ 20k (motul 300v as usual)
The 08-09 had a spindly shift shaft that they updated in '10. It's relatively cheap, and if your capable of getting your clutch basket off it's an easy switch to the '10 shift shaft. Replacing the the clutch plates while you're in there is a good idea too as they tend to stick and not release the tranny on a downshift. I'm in the middle of fixing the same problem.
1 - 5 of 5 Posts
