Search didn't bring up much info.
Looking for some starting numbers for adjusting cut times with Flash Tune on a 2017 ZX10R.
Issue that led into this was the bike not shifting from 4th to 5th at high RPM under a load. Once I completely disconnected the QS, bike shifted old school just fine (still ran like a raped ape, but I miss my autoblip!!!).
Currently have Graves rearsets, GP shift. Also have a set of Bonimici rearsets for the bike.
Problem is obviously electrical, and since it works in all the other gears and under lower RPMs, I'm guessing it's definitely an issue with the cut times, not a loose wire or bad connector.
Just looking for some people who would have some specific numbers we can try to adjust this via Flash Tune. Do NOT have a kit harness. Time crunch here, so don't really have a ton of time to just play around with it and "see what works" so hoping to at least get some base numbers we can tweak but will get us in the right direction.
