1 - 9 of 9 Posts
ok ,fellas
i'm have 04 zx10 it has 5202 miles on it right now
i'm new to the site and read up on throttle slack and
i went ahead and took off the fuel tank and air box to get
to the throttle cables i adjusted both cables so there was just a little slack
in the throttle.then i put everything back together and now it makes
rattle noise when i ride it ,when i get on the gas it sounds fine when i let off
the rattle nosie sounds off and it louder that the exhast which is a muzzy slip on.So i went back and took the air box back off and placed silicon around the gasket to make sure there is no air leaks and it still has that dam noise.
i don't know what to do now
please help me
BluDevil
Rent this space
Can you be a little more descriptive with the noise.
One thing I have found about removing the tank is the rear pinch bolt and rubbers can cause a lot of resonance in the tank , the steel tube that the bolt runs through(inside the rubbers) was a tad too long , I filed a little off and now it is fine, I still get a little noise on decel with a low tank.
ok i know there is an air leak now i can hear a whisle of air too but the nosie is on decel as well it sounds like afast clicking on the right side of the bike
Rent this space
The whistling is probably from around the gas cap , that is normal.
I am unsure of the fast clicking noise, are you sure it isnt the reed valves in the evap system.
Rent this space
Check to see that all your hoses are connected to the Kleen system , sounds like one of them has come off.
1 - 9 of 9 Posts
