I just went to start my bike (rode it two weeks ago). It started right up and then missed and died after a minute or two. Couldn't start it after. Narrowed it down to fuel injectors not firing. If I manually apply voltage to them while the fuel line has pressure they click and spray. I did that for all four, tried to start, and it ran for a second because of the fuel that came out. I have re-seated many connections and am at a loss. As stated spark and fuel pump are working. No FI light/symbol. Bike is in neutral, so kickstand/clutch switch are not part of this. Tilt sensor would be causing an FI symbol when cranking (I also tested the sensor output voltage and it is around 4.05v which is what it should be). I would think a crank/cam sensor would both throw an FI light AND prevent it from running at all like it does when I apply voltage to the fuel injectors.
