1 - 5 of 5 Posts
Hello,
I have a gen 1 , i have by addicent removed the - terminal from the battery when the engine was running. Now i dont have a spark anymore. There are no codes. Everything looks normale the pump butterfy valves working, it cranks.
I have checked every wire connetion and fusses. I have checked the crank sensor it got like 500ohm. But the cranking volt is 1.9 volts. Sould this be the problem the Manuel is saying 3.5volts or more馃
Could it be the security system? Maybe flash the ecu. I killed my Ducati battery when I first got it, then tried to reatart with it hooked to a charger. It caused the ecu to throw the alarm and the bike wouldn鈥檛 turn on until it was reflashed at the dealership. I know my 05鈥 ZX-10R has a security feature, but I have never tripped it.
1 - 5 of 5 Posts
