1 - 2 of 2 Posts
Hello guys, I’ve ran out of ideas short of just buying a new head unit. The speedometer has never had an issue until a week ago and I’ve owned since new. It probably displays mph, time, temp everything in lower section of gauge cluster, but as stated you can’t see it at night bc it no longer is back light.
Also RPMs don’t read At top of cluster. They don’t show where it goes across during ignition kick from key. No rpms show at idle, and don’t work while riding either.
However they do kickin like a faint flicker above 10k rpm. But back light still never goes on no matter how high I rev.
I wish I could post a video in here to show the visual.
I’ve checked wires best I can, checked fuses, tested battery. I’m out of ideas before I go spend 1000 on a new head unit.
You just need to verify the proper voltages on the proper pins at the plug to it. If those are correct, then the only thing left is the cluster itself. Sounds like it's the cluster.
1 - 2 of 2 Posts
