1 - 10 of 10 Posts
I Need some help, I have a 2004 zx10r it was running fine I put it in the garaged and next day when to turn it on and there is no power to the dash board as I turn the key and the bike won’t start. I have checked the battery and the fuses and they are good. What can it be and what can I check to fix this problem?
BigCat for Prez!
Check the main fuse. Its near the battery to the right and is seperate feom all other fuses. Its a 30amp. Itll be under a little cover
Sent from Motorcycle.com App
No power. Battery or fuse is blown. Or ignition switch is bad.
Thank you so much for the help. It was the main fuse near the battery to the right and is separate from all other fuses.
BigCat for Prez!
BigCat for Prez!
And he has campaign funds to seek out...wait, you used our campaign funds for the ThunderCat didnt you?
BigCat for Prez!
1 - 10 of 10 Posts
