1 - 16 of 16 Posts
Banned
i just bought a dry nitrous kit for my 04 10. the kit comes with 15, 30, and 40 hp pills. what do i need to do to make my bike run with this kit. when i richen the fuel on my power commander, do i richen it all the way on the high side? if i used a 40 shot, would my bike stand up when in the high gears, 4,5,6? my bike is slightly under 60 inches. i am going to have it sprayin when i hit my starter, i already have an airshifter using my horn. i plan on not sprayin the bike all the time, just when money is on the line. what is the best pill to use? i am running 9.4 on motor. should i expect to cross the line and actually hit a high 8? where is the best place to put my bottle so no one will see it. the kit comes with a 1.25 lb bottle. how many passes should a bottle last me???????
i use the mps instant rich fuel controller and it works awesome. you can run it with a pc so you dont have to have 2 maps.with a pc only, you need to take to a dyno so you know your not to lean or to rich. i have a 55-60 shot on mine and it hasn't came up yet but i also have the stock tire on it. i spin alot so i'm changing over to a shinko 003. i'm also 6 inches over and i put my bottle between the swingarm and tire. it will be hard to hide a bottle on the 10r. you could try to rig up something with the solo seat.:dontknow: if you have any problem with the installation just pm me. :eek:ccasion1
You really have to get it tuned on a dyno to know where the A/F is. Did you, by chance, get the muzzys kit? It shouldn't come on you alot with the length of your bike. Why use the starter button to activate the solenoid? Use the the lap button. Thats what I did and it works great.
Banned
the kit will be here in a couple of days. i will try the lap button. i have a big race lined up on mothersday. i know i wont have the bike dynoed then. could i just manually adjust the fuel the the richest it will go on the high rpms? im gonna just hit it when i feel i need to. dont want to win by too much. what kind of 1/4 mile times would you estimate? oh,,i didnt get the muzzy kit..i got the dyno tune kit..
your bike might run like shit if you rich it too much and you dont hit the nos and you dont want it too lean. if its too lean it will blow your motor. :dontknow:
Banned
does anyone have a map for nitrous that they could send me? i have a full muzzy exhaust and stock filter.....
What elevation are you at? You really need to tune the nitrous on the dyno. Too lean & you will need a new motor. Too rich and your big race turns into a big loss and fouled plugs.
I would screw with nitrous without tuning the bike properly for it. You could have a very expensive race on your hands. Quit being lazy and get it done the right way. It won't take too much time or money to have it set-up properly, but if you don't you could be buying a new motor.
:angryfire If You Stick With The Small Jet On The Dry Shot You Need Not Mess With The A/f Ratio Or Retared The Timing I Had A Dry Shot With A 20 Hp Shot On My 03 Gsx-r 750 And It Shaved A Little More Than A Half Sec Off The 1/4 Mile Time With Out Changing The A/f Ratio We Dynoed It And Everything Come Out Great TILL WE PUT THAT WET KIT ON THERE IT WAS A ROCKET YOU CAN READ ABOUT THAT UND NITROUS BOO BOO ON THIS SITE IF YOU WANT
I get this type of attitude all the time at my shop when i'm bulding engines or tuning them...you could get real lucky and install the kit and it goes out there and runs perfect and you when the race you have setup and it could go extremely bad for you too...if that bike is running on the lean and you spray it it's gonna cost you the race and your motor...put the race off until you know your bike is ready to run...don't rush things like this because things like this are costly one way or the other...good luck!!!
dwayne
Ok can sombody explain to me why you would need to adjust fuel at all on a dry kit? The computer will calculate the extra air from the nitrous from the sensors and add more fuel when it sees more air. There is no need to adjust for the nitrous, it is done autmatically for you by the computer. A dry kit means the air is induced before the amount of air entering the motor is calculated.
like i said previosly as long as you keep the shot small you can just run the bike stock if you go over a 30 shot you need to retard the timing a couple of degrees depending on the size bike/motor
Banned
Ah yeah, don't listen to this guy, obviously!! Lot's more OXYGEN molecules not enough FUEL molecules = BOMB!!!!
This is absolutely WRONG! You NEED to add more fuel with a dry kit. The sensors and computer cannot compensate for the nitrous. Don't believe me? I have plenty of dyno runs to prove it.
sonic397 said:
Hope this isn't too off topic, but how much did you pay for your nos kit intalled?
I bought the muzzys kit from ryan schnitz and installed it myself.
1 - 16 of 16 Posts
